125mm cranks for muni
Anybody prefer 125mm cranks instead of 150mm for muni?
Me. Among many other people nowadays. With a good brake you don’t need super long cranks anymore and it’s a lot less disadvantage (if any) uphill than people think.
For me I can’t get on with short cranks despite trying , I don’t know if it’s because of my height and long legs or having ridden mtb all my life on cranks around 170mm mark.
I don’t like the little circle feel with short cranks, my unicycles are on 138-150s.
I certainly wouldn’t call myself a good muni rider so i like the extra control with longer cranks, I’m not concerned about loss of speed with shorter cranks.
After many years of unicycles I don’t like the long cranks on any of my bicycles any more.
I have 137s on my most ridden off-road unicycle right now, but it is a 32".
With the advent of really good brakes and lighter parts I think most riders have ended up with shorter cranks.
I can’t imaging riding with 150mm on any unicycles now.
no comment
Another benefit of short cranks on b!kes: fewer pedal strikes. If you notice the configuration of a lot of the electric b!kes, they have short cranks, presumably for that reason.
It’s also easier on the knees. No need to have super long cranks if you’re never powering up a hill just using your muscles.
A friend of mine on his electric bike years ago got pretty much the shortest cranks he could find as due to knee problems that was the only way he could ride without pain. Highpath Engineering’s swing cranks serve a similar purpose, and get the circle of rotation lower down: Pulse Swing Cranks from Highpath Engineering
In my opinion, crank choice depends on the type of riding one does. And wheel size, of course.
I started muni with 170mm cranks on 26" and used them for several years.
When the new splined hubs from Qu-Ax came out, I decided to change to that standard. Unfortunately, the longest cranks Qu-Ax make are 145mm. Somewhere in there I also switched to 27.5" (650b).
There is no argument that the difference in leverage between 170mm and 145mm is massive (and can be easily verified with simple calcs).
I persisted with the shorter cranks and while initially not able to ride as technical features nor as steep uphills (both of which I like), over time I overcame the struggles and now ride harder than I did with the longer cranks.
Lots of practice and my technique has improved over the years.
I wouldn’t go back to 170mm cranks, even if Qu-Ax offered them.
But I wouldn’t put 125mm on either, unless perhaps on a much smaller wheel.
If you predominately ride downhill and less technical features on a 27.5" or thereabouts wheel size, 125mm may work.
If you like uphill and super technical riding on said wheel size, 125mm may be too short.
I think that European muni riders generally use shorter cranks than their U.S. counterparts. Not sure why that’s the case. Perhaps more lift access from ski areas plays a part. Maybe they’re just better riders.
In any event, good luck with your experimentation.
I started with 159mm, then 138mm, 135mm, and 125mm on my 27.5" wheel. After riding with 125mm for a while, I find them long enough for most terrain, except for very steep uphills. I think the routes I couldn’t ride through with 125mm cranks, I’ll still fail with longer cranks. Recently, I’ve been trying 110mm, which I heard many skilled riders use. They do feel short and make uphill much harder. Besides, it also makes me frequently UPD during downhill due to my poor braking skills.
125mm for everything! 20 inch through 36 inch. Great for consistency, my feet know where a pedal is supposed to be no matter what I’m riding, even a '70s road bike I converted to 125mm. For muni there is enough torque to break loose a 29er with a Maxxis Minion on it when the ground is a bit dry on a steep uphill. Also, the more q factor the better, keeps my heels away from the cranks.
As long as the Q is in the cranks, not in the hub.
125mm for all my Muni riding for the last 7 years at least. That includes fast XC, big adventures (like Grischa Muni Challenge) all the way to technical downhill (like following Kris Holm at the Vancouver Muni Weekend).
I used to ride 137 and it was a really good size too. The shorter cranks feel like the bumps on the ground dont hit as hard, I tend to keep my feet on the pedals more with the shorter cranks. It feels smoother, and less pedal strikes.
I tried 110, like lots of european riders and I just couldn’t like it. 125 paired with a light wheel feels just right.
If you look through the forum, Kris had started a conversation years (and years) ago when he switched from 150 to 137. It’s really interesting to read :slight_smile:
Experiment and find what works best for you!
Hello,
For me, this is definitely a positive thing, just as the previous speakers explained. However, the setup on my unicycles also features a lightweight wheel combination. The advantages of the short cranks are better directional stability—the unicycle doesn’t wobble as easily and runs more smoothly in its lane. You have less control and power, but you don’t always need them everywhere. On straight paths or easy trails, I found the 125s to be a pleasant improvement. However—and this brings us full circle—with my KH Spirit cranks, I usually use the larger 150mm diameter. So I do find something to like about the control and power transfer as well. With the current rainy weather, I like to take the 27.5-inch bike with 150mm cranks into the woods. In dry conditions, though, I also enjoy riding my 26-inch unicycle with 125mm cranks.
regards Chris
My 26" Muni runs with 150 mm Cranks, works very well. My 24" Muni runs with 125mm Cranks and works also well for me. Long Cranks are not a mistake.
