Yuni 20" Trials - Any good?
Can anybody please tell me if the Yuni 20" trials with the Profile setup is any good. I’m strongly considering buying it, and it looks really good to me but I’ve noticed that nobody really talks about Yuni unicycles. You always hear about United and all these other brands but not about Yuni. Is there something wrong with Yuni, or are they just a new brand or something? Also, I’m wondering why the Yuni 20" trials with the Suzue hub is so much cheaper than the Pashley 20" trials and the Semcycle one. To me it seems to have better parts on it like the Monty cranks and the Alex DX-32 rim. Finally, if I’ve saved up enough money for the Yuni 20" with the Profile setup, should I get that one or settle with the Yuni 20" with the Suzue hub (I’m planning to work my way up to doing around 6’ drops).
Thanks,
Andrew Carter
Hi Andew,
I can’t speak directly to your question regarding the 20" Yuni but do now ride a 26" Yuni off road and the quality of the frame seems to be great. The more I ride the more I am convinced that it is all about the wheel (hub, cranks, rim and tire). The biggest concern, for me, in buying a frame is if the tire that I want to use will fit through the fork blades with enough room. I’ve bent wheels, ruined cranks but I’ve never broken a frame that was an end-cap bearing design.
Tommy
Thanks for the advice Tommy, you’ve been really helpful.
Re: Yuni 20" Trials - Any good?
It is a new brand.
Why stop at 6’ when you can do more?
Ben Plotkin-Swing should reply to this post, he has tons of experience with
this setup, although I think he has a monty rim.
I only have experience with the “Yuni” frame on my MUni and it’s great!
If you have the money for the profile setup, buy it, you wont have another
crank/hub related problem again!
Dylan
andrew-
I just got a new muni (seperate parts that i put together) last weekend with a profile hub and a 24" yuni frame. So far ive had about 3 serious riding sessions and I am blown away! Ive done a couple 3-4’ drops without any problems but this was landing in dirt/leaves. When im goofing off with the one-footers, I appreciate the way the yuni crown tilts my foot in towards the seat… very secure. 2 of my friends that i ride with have had profile hubs forever and im sure you know that they are great. One of the boys had a lil trouble with his bearings, sent it back, and got a brand spankin new one with the warranty.
  I would strongly recommend against the suzue hubs because of its cotterless design. I started out on a monty trials (20")with a united frame and suzue hub. I am now on my 5th set of cranks with that beast, although i dont ride it too much anymore.  I just have not found a set of cotterless cranks that will put up with the abuse of high drops onto hard surfaces. (If anyone knows of decent cranks, please let me know). The monty tire(and rim), on the other hand, has withstood 2 years of torture flawlessly. The grips on the tire are completely worn smooth, that should give you an idea of use. No complaints with the united frame either, just that the rounded crown design makes things a little more difficult with the one-footers.
 Sooooo.... go for the profile hub especially with the potential of "6' drops" on the horizon. It will be a much better investment. And so far, yuni rocks!
-erik
I agree with Erik.
In my opinion, if you are doing anything that involves hops and drops I would recommend the Profile set-up. One of our club memebers, Ted, has tried everyting and teh only thing that works for this extreme lad is the Profile. I have the Yuni 26" with a 24" wheel w/ profile. Again, the frame seems to be awesome. The welds and finish seem great and the Yunis in general seem to be a real bargin.
Tommy
Thanks everyone. I’m almost certain now about getting the 20" Yuni with the Profile setup.
hey dylan do you use the 24 or 26 inch frame?
I actually use the 28" frame. I got it from unicycle.com in the UK before they
were in the US (they didn’t have 26" and I thought the 24" was too small)
Dylan
You would recommend against the Suzue setup only because of the cranks? I was thinking of getting the suzue/monty wheelset and a yuni frame, and I am glad to hear all the postive feedback on the frame. However, the wheelset comes with lasco cranks, which I’ve heard break fairly easily. Would you still recommend against this setup if it had different (stronger) crank arms? Or is the hub no good also. Thanks!
topside
yes i can reccomend the 20" trials yuni with profiles.
Ynui frames have been available in the u.k. for ages. but here there called nimbus ii.
i’ve been riding a nearly identical setup for a few months now.
the only diferences are, iv’e got a monty rim and a viscount seat and a reeder handle.
i’ve had the Yuni frame since january, i originaly had a suzue hub and bycycle euro cranks, which got broken and replaced a few times before i had enough cash for the profile hub.
the suzue hub died after doing 3-4foot drops. and the b.e cranks got replaced far too often from just doing gaps.
when you compare the profiles against the suzue/monty setup, think about the hub rather than the cranks,
the profile has a big thick cromoly axle with a liftime warrany, that dosent bend.
the suszue has a rather weedy steel axle that bends and breaks easily
and even if you look at the cranks its the same story
profiles don;t break and montys do.
when the montys arrived loads of people tried them and found that they bend and break just the same as b.e. cranks.
even if you had a suzue hub with unbreakable cranks then youd still end up breaking your suzue hub.
if your serious about trials you realy need a profile hub. or else you’l have to spend a fortune replacing hubs and cranks
stay clear of the lascos, i’m sure that theres no serious trials rider that would recomend them.
I rode a United/Monty/Profile setup for a while, and was about to switch to a Yuni frame before my neck injury. It’s definately a bomdiggity setup.
Ok -I was just checking prices out, sorry to sound like such a newbie, but I just have 1 last question to make sure I’m not missing anything. If I buy this:
http://www.unicycle.com/shopping/shopexd.asp?id=550
The profile wheelset with the monty tire, that comes with cranks, hub, spokes, rim, rimtape, tube, tire. Then I also get a yuni 20’’ frame and a miyata seat with post, I have everything I need except petals? (I have a pair of nice platforms already) And this should all fit together nicely? I just wasn’t sure about the hub/frame/crank arrangements. Thanks!
topside
Get a set of Snafu.
Thanks again everyone. Hey ‘topside’, can you tell me what you think of your setup when you get it please?
What’s ‘Snafu’? Is it just a set of cranks, or both cranks and a hub, or smething else?
bmx parts, lots of people like they’re pedals
Accord NSX (Adam) is probably referring to pedals when mentioning Snafu.
You can always call Unicycle.com and ask them if they can sell you the wheel set without the lasco cranks and have them substitute some other brand of cranks.
I noticed at the CAL MUni weekend that the tire side clearance on the Yuni frame seemed a hair more than the tire side clearance on the United frame.
