Yesterdays The Wellingtonian Newspaper. Was an OK article- the reporter got most details right- but we will not be having an artistic freestyle comp at the NZUNI weekend at this stage:
Can you post a higher resolution scan in a gallery? The one here is very difficult to read due to the low resolution and JPEG compression artifacts.
Sorry, I usually end up posting it too big…Hope this is the right size:
edit
That didn’t work- must be my 56K connection. I’ll try again later. Meanwhile, I guess you’ll need a magnifying glass
It would probably be better to post the bigger version in a gallery rather than attaching it to a post. It’s going to be too big to reasonably attach to a post. The people on dialup will be hating you.
Starting with a bigger scan (more resolution) and then compressing with GIF or PNG will give better results. JPEG compression does bad things to small text (makes it blurry).
