Okay, so I have now installed all four of these tires on my KH 29er, much to my chagrin
The winners:
Largest Casing/Volume = Navegal
Heaviest = Stout (duh!)
Lightest= Exiwolf
Stiffest Casing = Navegal
Ride review: The best muni ride was a split between the Rampage, Stout, and Navegal. The Exiwolf is a little less sticky, I also found it washes out at low volumes, likely due to the light weight casing. I like the Rampage, but it was smaller volumed by ever so slightly that the Navegal, so I rode the Navegal until I got the Stout. Across the board Iād say that the Navegal has the stiffest casing, then the Stout, then the Rampage. The Stout and Navegal are rated about the same on rubber āstickinessā, though the Stout seems stickier.
The loser: Me! Because I believed the hype and bought yet another damn
29er tire!!
Fortunately I have a 29er mtb, so I can use the tires on it, nonetheless I am a bit irritated, esp since I just went to the trouble of dismounting the Navegal to mount the Stout.
In summary, if youāre running a Navegal, keep it. The rubber is just as sticky as the Stout or Rampage, plus it has a little more voume over the Stout. If youāre buying a new tire, Iād get the one thatās on sale (Rampage, Stout, or Navegal.
Tire Shopping? Check out www.bike29.com sometimes they have deals.
Here are some dimensions comparisons:
Navegal 29er:
Casing Cross Section 2 1/4"
Casing Height 1 7/8"
Tread Cross Section 2 5/16"
Stout 29er:
Casing Cross Section 2 1/8""
Casing Height 1 15/16"
Duro (24"):
Casing Cross Section 2 1/2"
Casing Height 2 3/8"
Tread Cross Section 2 3/4"
Kenda Kolossal DH (24"):
Casing Height 2 1/16"
Tread Cross Section 2 9/16"
