How can I create a shortcut to open the command prompt with the current
working directory set to, say, c:\winnt\profiles\mking\desktop???
is there a way that I can set all command prompts to open at the
same folder?
-Mike K.
same folder?
-Mike K.
make a shortcut to the command.com, it in the winnt\system32 in 2000 then
go to properties, click the program tag and change the working to
Tony Raineri http://www.woogu.com
“Mike King” <mike@webcodefocus.com> wrote in message
news:3B73DBAC.3AF6EC1D@webcodefocus.com…
> same folder?
> -Mike K.
Thank you Tony!
-Mike K.
> then go to properties, click the program tag and change the working to
> > current working directory set to, say,
> > is there a way that I can set all command prompts to open at the same
> > folder?
> > -Mike K.
