Will this fit?
What I am wondering is if my 19" rim on my k1 http://www.peppl.com/Unicycles//Try-All/HDDB458172aa5fd27 will be able to fit a Maxxis Creepy Crawler http://www.unicycle.com/shopping/shopdisplayproducts.asp?id=2&subcat=33&cat=Tires+-+Trials&L2=Tires%2C+Tubes%2C+Rim+Strips+and+Valve+Caps&L3=Tires+-+Trials
I’ve used the search function but havent turned up anything that Is the only reason I am asking.
Yes, it will fit the rim. The real question is whether or not you are using a K1 frame with the super close clearance, I’m not sure if the tire will rub.
UniSLAB advised me that he wanted to switch tires so he could have more clearance in his frame. I think I’ve heard that the CC has slightly more volume than the try-all though I’m not sure. If someone would like to chime in as to whether or not the outer diameter or the CC is smaller than the try-all I’m sure he and many others would appreciate it. I suggested shimming the frame up with some slices of soda can in the bearing holder to increase the clearance in the meantime.
