will the KH spooner fit on the HT-2 Magura dic brake?
If it’s the same type lever that comes standard on the nimbus oracle and Oregon, the answer is yes, if you snip off the very tip off of the lever. If you don’t want to alter the lever, then use the KH Starfighter.
A Shimano STX fitted the spooner after I trimmed the end :stuck_out_tongue:
Right. I cut the tip off the lever the day I got my Oregon, and the spooner fit perfectly.
If you meant the Magura MT2, no and I don’t think cutting the end of the lever will do the trick, I’ve just checked, the lever is too wide
