If Kris is out there…
Will the new rollos sold on UDC work with moment cranks? The description says it will work with Spirits…I assume it will work with moments too…
There are two different types of rolos as far as i know: one for moments and one for spirits and you can’t mix them up. See http://krisholm.com/en/gear/component/rollo-disk: “Crank Compatibility: Spirit & Moment (different Rollo Disk versions for each crank model)”
Ah, you are right. http://www.unicycle.com/kris-holm-rollo-disk.html
These are for moments. I better pick them up while I can.
