sorry for the new thread folks, I searched a little but was unable to find. I’m looking at buying a Muni online, however the one I’m looking at has the old style KH cranks/hub. Is it possible to swap those cranks out for Moments without replacing the hub? If not are there any other cranks that are compatible with the old style hub and still readily available?
if its isis there compatible
If you mean the KH/Onza hub, no. None of the currently manufactured uni cranks will fit.
KH/onza cranks are still strong so there should be no worries there. If you want to change length, UDC may well have shorter cranks in stock.
Saying that, in some cases the cost of replacing those old cranks is more than upgrading to an ISIS hub and cranks!
