This time I’ve been working on wide Coker hubs. They (hopefully) are the same width and dimensions as the wide hubs that have already been made. I’ve got some pictures in a gallery here:
The hub looks great. Thanks for posting the process, as always, it’s great seeing your creations step by step.
Will these be available for the “masses” anytime soon?
That looks great, does it still fit in a regular sized frame? Could you please explain the bent-inwards flanges in the diagram? It’s really interesting to see the differwent stages of production.
I’ll probably make a couple more … that should satisfy the world wide market for these things!
I used my most favorite metal in the world: 17-4 ph stainless steel. It’s really good stuff because it’s easy to machine (as far as stainless goes), simple to heat treat and is very tough. The flanges are just common 304 stainless steel. Another nice thing is that it’s stainless so all it needs is a good bead blasting and it’s finished … not other finishing is required and it’ll never rust. Naturally, it can be powder coated or chrome plated but it doesn’t need to be.
Dishing the flanges inward lines them up to the angle of the spokes. This helps prevent the outer spokes from having to bend where they exit the flange.
“Heat treating” is the general term for changing the molecular structure of metal by heating and cooling it in a controlled way. Usually raw metal is purchased in an “annealed” state. This means that the metal is soft and easy to form or machine. After the metal is worked into it’s final form it’s then heat treated so it has the desired properties - usually stronger and/or harder.
Some heat treatments require heating the metal to a high temperature then cooling in oil, brine or water. Sometimes more than one heat/cool cycle is required. Knife making is an area where heat treating the blade is as much an art as a science. Different knife makers have their own “recipies” for heat treating so their blade has some unique or desired characteristic.
17-4 ph is really nice because it’s easy to heat treat. After machining (and welding in this case) it’s heated to 900 F for one hour then allowed to cool in the air.
Well Steve, you know what this means? You’re going to have to build yourself a custom wide hub Coker. Send one of those hubs to U-Turn to build you a wheel. Build yourself a special SH Coker frame to fit the wide hub. And experience for yourself what it is like to ride a real man’s Coker.
