Who's using shims with their Schlumpf?
I know a few of you are using square taper Schlumpf hubs on frames with 42mm bearing holders. I need real world opinions here from people who have done it.
Problems?
Aw, come on…
nobody uses shims on their schlumpf? even on the non torque arm side?::frowning:
I haven’t seen anyone who does this. It is a bad idea with the torque-bearing version of the Schlumpf hubs (KH or square taper).
corbin
It should be fine with the original Schlumpf with the lever arm connected to the frame. But it would seem to risk failure with any of the current models.
