This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_000_01C0E3E4.43C5D0A0
charset="iso-8859-1"
> Concerning the strength of the axle, specifically for say street trials,
> did anybody already damaged the suzue axle coming with the monty
> wheelsets from unicycle.com ?
Speaking as a user of Suzue axles for many years I can offer this:
The Suzue is a very good axle, but no standard unicycle axle will last
forever under prolonged hopping and drops. It is only a matter of time
before the steel fatigues and cracks apart. How long is entirely dependent
on your weight and riding style.
I would venture to guess that a Suzue axle should last longer on a
Monty-style wheel than on a wheel with a skinnier tire. The bigger air
volume in the tire should absorb a lot of shock so less stress goes
into the axle.
So go ahead, hop and drop! The axle probably won’t last forever, but it
was made to be used.
Stay on top (and wear your pads), John Foss, the Uni-Cyclone
jfoss@unicycling.com www.unicycling.com
Frisbatarianism (n.), The belief that, when you die, your soul goes up on
the roof and gets stuck there.
------_=_NextPart_000_01C0E3E4.43C5D0A0 Content-Type: application/ms-tnef
eJ8+Ih8XAQaQCAAEAAAAAAABAAEAAQeQBgAIAAAA5AQAAAAAAADoAAEIgAcAGAAAAElQTS5Na-
WNy b3NvZnQgTWFpbC5Ob3RlADEIAQWAAwAOAAAA0QcFABcAEAA6AB0AAwBeAQEggAMADgAAA-
NEHBQAX ABAAOgAdAAMAXgEBCYABACEAAABCRkVFMkQ5NEJDNEZENTExQTMyQjAwMDJBNTI4N-
TE0MgAlBwEE gAEAHQAAAFJFOiB3aG8gZG9lcyB0cmlhbHMgb24gYSAyNCIA3wgBDYAEAAIAA-
AACAAIAAQOQBgAw CQAAMgAAAAMACVkBAAAAAgFxAAEAAAAWAAAAAcDj5FwSfDgAwVQ+SFq5n-
MQ8ui1VmwAAAwDeP69v AAADADYAAAAAAAMAGYAIIAYAAAAAAMAAAAAAAABGAAAAAFKFAAAna-
gEAHgAdgAggBgAAAAAAwAAA AAAAAEYAAAAAVIUAAAEAAAAEAAAAOS4wAAsAhIAIIAYAAAAAA-
MAAAAAAAABGAAAAAAaFAAAAAAAA AwAegAggBgAAAAAAwAAAAAAAAEYAAAAAAYUAAAAAAAALA-
AqACCAGAAAAAADAAAAAAAAARgAAAAAD hQAAAAAAAAsAJ4AIIAYAAAAAAMAAAAAAAABGAAAAA-
A6FAAAAAAAAAwAAgAggBgAAAAAAwAAAAAAA AEYAAAAAEIUAAAAAAAADACiACCAGAAAAAADAA-
AAAAAAARgAAAAARhQAAAAAAAAMAKoAIIAYAAAAA AMAAAAAAAABGAAAAABiFAAAAAAAAHgA5g-
AggBgAAAAAAwAAAAAAAAEYAAAAANoUAAAEAAAABAAAA AAAAAB4AOoAIIAYAAAAAAMAAAAAAA-
ABGAAAAADeFAAABAAAAAQAAAAAAAAAeADuACCAGAAAAAADA AAAAAAAARgAAAAA4hQAAAQAAA-
AEAAAAAAAAAAgEJEAEAAACoAwAApAMAAF0FAABMWkZ1BAeOqAMA CgByY3BnMTI14jIDQ3Rle-
AVBAQMB9/8KgAKkA+QHEwKAD/MAUARWPwhVB7IRJQ5RAwECAGNo4QrA c2V0MgYABsMRJfYzB-
EYTtzASLBEzCO8J97Y7GB8OMDURIgxgYwBQMwsJAWQzNhZQC6YgPhkSIW5j BJELgGcgdOBoZ-
SBzdBggHZAdwAggb2Yds2F4bGV6LB3wcAWQBpAN4AdAbMx5IAIQBcBzYSAQCqK/ CoAc8B4CF-
CAdsAcicx9ASGRpZB7wbnkG4GSXIBAHQBggYSKxZGEAwOZnCYAdtHV6ClAe8yCn/QWg bR2CA-
/AeYR3CBGACMPUgEHcd0GUh4BQgBCADUkQgdQMAY3ljHyAuWSVRID8gpSC0Ux9wYeprHYJh
BCBhJ5AUEAXAfR6RUyQ3JzEFsQOBIBB5cyMQFAAgSSVAA5EekGbXEoEdwAQAOiiaVB3RKrSbB-
AAq AXYEkCAQZ28EcMke9WJ1BUBubx3xAHC/I2ALICeXJHQD8B/wIAtgOx4AICJlLyEnkQSBI-
HAPA2AX sB2QI7Fob3BwjymjMMAiEANgcHMuLFD/BUAu0QIgIAEqEADAAkAqVP50B3EwEAEQM-
rEdtSbRICD5 NjBpZwpQKfE0sQUAANCWaynxCrF0NTBIbwfg/zOyLsIJ8DbAGCAgAQEAH3C/M-
zECMDWhK/AIYSWw ZThQfmgFQDSiBRAiIB2RHgB51ygBKJosYHcIYGwiQC8g/wIwCHA3YTBwO-
GIEIB3ANjD/KgEquB3w NCA+wjJTM7MqYesDoCoQTSZiLT1jJqRAAt8soUJyQ3QlwyoQcymRA-
wDvLPI6wTUwLjJiOFBCIgtw 9QXAdgbwdTbhC4Adszqy60EmAaBzBbBiKgEXsDuh/x6gQTE5I-
B3wMHArMQQgHgJ/BBEvcAeRC4A/ gR7GPbtT+z+RMHBhHdAjIB9ANCE0l+4hRiMkgzOBYgGgI-
AE+oPxuJ0HRMmkwBCXQJbAp4d8AwAEA P3I3ECoiZEw8AZDvIBA7wT+ATfAoNKI8QArBQzvzC-
rBkcyksILRK5G9oA6BGbwQQH0AdwrJVAwAt QyfhAiBlILT2agIQBBBAJ6UdgSgiILS6d1mQL-
lhfKMcgtEYFEF5zT3ABkAchAwBzJ4Ao/G4uVXBG JCbgCJAeojYw/x9AJrE70yIRHzE780jgP-
sD9SwR1TfBT0h3RA2AekTSi/yOgJyEeABrQSgAdwUXx ILQCfWLAHgBwAAEAAAAZAAAAd2hvI-
GRvZXMgdHJpYWxzIG9uIGEgMjQiAAAAAAMAJgAAAAAAAwAu AAAAAAALAAIAAQAAAB4AQhABA-
AAAMAAAADw1MkNEMDJDM0RBRDJENDExQTMxNzAwMDJBNTI4NTE0 MjI1QzY4NEBTRVJWRVI+A-
AMA/T/kBAAAQAA5AKDQxUPk48ABAwDxPwkEAAAeADFAAQAAAAUAAABK T0hOAAAAAAMAGkAAA-
AAAHgAwQAEAAAAFAAAASk9ITgAAAAADABlAAAAAAAMAgBD/////AgFHAAEA AAA2AAAAYz1VU-
zthPSA7cD1BbmRlcnNvblNvbG9uZUluO2w9U0VSVkVSLTAxMDUyMzIzNTgyOVot NTcAAAACA-
fk/AQAAAE8AAAAAAAAA3KdAyMBCEBq0uQgAKy/hggEAAAAAAAAAL089QU5ERVJTT05T T0xPT-
kVJTkMvT1U9U0FDMC9DTj1SRUNJUElFTlRTL0NOPUpPSE4AAB4A+D8BAAAACgAAAEpvaG4g
Rm9zcwAAAB4AOEABAAAABQAAAEpPSE4AAAAAAgH7PwEAAABPAAAAAAAAANynQMjAQhAatLkIA-
Csv 4YIBAAAAAAAAAC9PPUFOREVSU09OU09MT05FSU5DL09VPVNBQzAvQ049UkVDSVBJRU5UU-
y9DTj1K T0hOAAAeAPo/AQAAAAoAAABKb2huIEZvc3MAAAAeADlAAQAAAAUAAABKT0hOAAAAA-
EAABzDO8sVD 5OPAAUAACDBEo9ZD5OPAAR4APQABAAAABQAAAFJFOiAAAAAAHgAdDgEAAAAZA-
AAAd2hvIGRvZXMg dHJpYWxzIG9uIGEgMjQiAAAAAB4ANRABAAAAMAAAADw1MkNEMDJDM0RBR-
DJENDExQTMxNzAwMDJB NTI4NTE0MjA2QjU2MUBTRVJWRVI+AAsAKQAAAAAACwAjAAAAAAADA-
AYQ46MN9wMABxArAwAAAwAQ EAEAAAADABEQAQAAAB4ACBABAAAAZQAAAENPTkNFUk5JTkdUS-
EVTVFJFTkdUSE9GVEhFQVhMRSxT UEVDSUZJQ0FMTFlGT1JTQVlTVFJFRVRUUklBTFMsRElEQ-
U5ZQk9EWUFMUkVBRFlEQU1BR0VEVEhF U1VaVUVBWExFQ08AAAAAAgF/AAEAAAAwAAAAPDUyQ-
0QwMkMzREFEMkQ0MTFBMzE3MDAwMkE1Mjg1 MTQyMDZCNTYxQFNFUlZFUj4A+xY=
------_=_NextPart_000_01C0E3E4.43C5D0A0–
