Hub/Axle: I personally think ISIS is much more durable than square taper and worth it for freestyle (although kids up to 15 do fine on square taper a they’re lighter). Q-Axle is fine but I think overkill for freestyle.
In the other hand, for Muni I have an Aluminum frame (Mad4One) and Q-Axle hub and the light weight is a great benefit.
For Freestyle weight doesn’t really matter and strength and durability are way more important than weight: durability to survive the thousand times the uni crashes to the floor trying to learn a new trick like wheelwalk or standup.
Thanks. On a side note, I’m doing a fair bit of freestyle right now, and this week I learned to jump up from the cranks to stand walk!! Tried it yesterday for the first time and then by the end of 2 hours I had done it 16 times! And today another 10 times in about 20 tries. I do have to say that doing stable stand walk feels really cool. Have fun with freestyle.
I briefly could ride a lighter freestyle uni and had that feeling, too. But wasn’t sure whether to trust that impression or not. The unispins you mentioned aren’t something I’m likely to ever learn (ok, 180° is somewhat tempting and could be within my possibilities one day).
Good to know. So the M4O frames are getting more and more attractive (and so does my cheap second hand Qu-Ax…).
I went from 125 to 114 and finally to 100mm a year or so ago. Had a hard time to get used to that but am doing quite well by now. Still, I can’t imagine installing shorter cranks for the foreseeable future. Have 89s lying around but no itch to try them out at the moment.
I just hope ISIS is there to stay for another decade or two. Square taper probably will for the cheap unis, but ISIS might be replaced by Q-Axle someday (see KH).
Yeah, the uni crashes kinda frequently, indeed…
Again, thanks for your comprehensive input, much appreciated!
@authoritimmy - how have those carbon rims held up? I’d be worried about breaking them, but I don’t have much experience with carbon.
Oh, that reminds me of my increasing paranoia about unicycle equipment: do you guys use spoke washers? I didn’t put any on my rim when I made it, and I am wondering if that was a mistake (I think my rim is Odysee Quadrant, double wall).
When needed.
I used them on a wheel with a Schlumpf hub, though only on the spokes that faced to one side - don‘t remember if it was in or out. The others were fine without the washers, so I left them as they were.
As far as I understand:
Washers needed, but not installed = unnecessary stress on the J-bend of the spoke.
Washers installed, even though not needed = unnecessary stress on the flange (and prolly on the J-bend too).
You may ask yourself how anybody could come up with the idea to install the washers even though they aren’t needed. Well, things are not always black and white in real life. That is also true of the use of spoke washers.
My 36" carbon rim has held up great for a good bit longer than the 20", and I prefer the 36 generally speaking. I did break one spoke but no problems with the rim. The 20" should be great but I’m a little careful about letting it get sun in the back of the car.
