Which One for my first trials
Hi Ive been unicycling for about 3 years now and I started out with a regular Torker 20" freestyle cheapo uni. And when i mean cheap i mean cheap. Every time i do anything but just ride the damn thing something gets bent. Now im looking at a trials because I want to start learning some cool new tricks. But im stuck b/t some choices. This will be my first trials unicycle and i am able to ride perfectly forward, I can idle, and i can almost ride backwards. Also if there is one that you think will suit me better than the two below plz let me know
Nimbus 20-inch Trials Cycle with ISIS hub
New! ISIS splined technology has become a new standard in the cycling industry. ISIS hub/axle/crank arms are designed to withstand more torque than a hub with a square-tapered axle and crank arms.
Now introducing our new Nimbus Venture Alloy ISIS cranks! These are a stealthy black, alloy crank we introduced to create a hard-core trials unicycle! Now comes with a KH Fusion Street Saddle for a limited time only!!
Features:
Hub/axle: ISIS-design
Crank arms: ISIS-design 125-mm alloy
Rim: Nimbus 36-hole double-walled 19-inch alloy
Saddle: Nimbus gel, coutoured with front lift handle
Seat post: 25.4- x 350-mm chromed aluminum seatpost with rectangular mounting bracket, 4-hole
Frame: Nimbus II chrome-plated low-carbon steel with machined main-cap bearing housings
Seat tube size: 25.4-mm
Seat post clamp: Nimbus bolt-style, alloy black
Bearings: 42-mm
Tire: Maxxis Creepy Crawler 19 x 2.5. This is a specific tire for this rim. A regular 20 inch tire cannot fit this rim.
Pedals: DX-style alloy with pins, 9/16 threads
Cycle Weight - 12 lbs
$290.00
OR
Nimbus 20-inch Trials Cycle with ISIS hub (Blue)
New! ISIS splined technology has become a new standard in the cycling industry. ISIS hub/axle/crank arms are designed to withstand more torque than a hub with a square-tapered axle and crank arms. Now available with a powder coated frame in blue!
Features:
Saddle:Blue Nimbus gel, coutoured with front lift handle
Seat post: 25.4- x 350-mm chromed aluminum with rectangular mounting bracket, 4-hole
Frame: Nimbus II steel powder coated blue with machined main-cap bearing housings
Bearings: 42-mm
$300.00
OR
Torker Unistar DX 20-inch Trials
2008 model. A virtual bomb-proof street freestyle unicycle with splined, heat-treated hub and flat crown!
Features:
Saddle - DX Saddle
S.P. Diameter - 25.4
S.P. Clamp Style - Double Bolt
S.P. Clamp Size - 25.4
Frame Style - Flat Crown
Frame Construction - Steel
Frame Finish - Black
Bearing Housing - Machined Bearing Housings
Bearing Size - 21 x 40 x 12
Rim Size - 19 inches
Rim Construction - Steel
Rim Type - Double Wall
Tire Size - 19 x 2.5 (19 inch trials tire). This is a specific tire for this rim. A regular 20 inch tire cannot fit this rim.
Tube Size - 20 x 2.125
Tire PSI - 50 max
Hub Type - 10 splined
Hub Construction - Steel
Spoke Count - 36
Crank Arm Length - 127mm
Crank Arm Type - 10 splined
Crank Arm Construction - Steel
Pedal Type - Street,Trials
Pedal Construction - Steel
Pedal Protector Size - Size #3
Cycle Weight - 15 lbs
$305.00
Get one of the first two the third one isn’t Isis splined, is heavier, and has a much weaker frame. An Isis splined hub is the standard in unicyle hubs and is used by most unicycle manufacturers.
EDIT: The DX also has a smaller rim width wise, the cranks have nub on them that can hurt, and the frame just isn’t great even if you don’t break it.
