is the nimbus http://www.unicycle.com/shopping/shopexd.asp?id=939 or the DX http://www.unicycle.com/shopping/shopexd.asp?id=939
You put both the same links…
I assume it was out of the Nimbus Trials and Torker DX? The DX will win because it is alot stronger, but it is heavier.
Or maybe it was the Nimbus Trials aginst the Torker LX? I would then say the Nimbus would win.
Mike
I think you should get the nimbus hoppley if It’s not too expensive. It’s a great uni.
To accurately answer your question we need to know two things:
what two unicycles
better how?
The closer one.
Get the DX. It has splined cranks. You don’t need a 48 spoke wheel.
The both have a 48 spoke wheel. But because the DX is splined it is a much stonger trials unicycle. I strongly suggest a frame upgrade to the nimbus II frame in the near future as the nimbus II frame is much lighter, stronger, safer, and better designed.
