Which is better?
hi,
i want to do trail or mountain unicycle but i want to know which is better between 20 inch wheel or 25 inch wheel for this kind of unicycling?
the rec.sport.unicycling forum is better
…as well as a brief look thru the rec sport unicycling pages or a search
The closer one is always better.
hey ive been unicycling for 2 years now and so ive found out that if your going down and up hills then you should get a 20" but if the trails that you go on are flat but rocky then get a 25" unless you get brakes then get the 25" but brakes go for 100+$
You seem to be very well misinformed for a god.
ok thanks, i think ill go for the 20’’ like you said
ok thanks, ill go for the 20’’ like you said
Don’t listen to him, he has no idea what he’s talking about. Go read some other threads, there are even websites which explain different unicycle wheel sizes. Do your research.
And above all, there is no such thing as a 25" unicycle.
yeah i wrote the thread before knowing that there aint a 25’', ok then ill do more research about it.
24", 26" and 29"…generally for trails. you can do muni on a 20" but it’s very slow, and youll get very tired of it very quickly and want a bigger wheel right away.
