what is a good inexpencive unicycle preferably below 200 im new so hi
I am new too but I’ve had good luck with a Torker 20". Most people seem to work well on a 20".
The 20" tire seems to be most peoples’s prefered learning size. If I am trying something new, I always try to master it on the 20" before trying it on a larger wheel. The Torker is a good starter model that will continue to serve you well as you progress. Torker makes a few different models. Check out the Torker LX. http://www.unicycle.com/shopping/shopexd.asp?id=634 It is well within your price range.
As said before, the Torker LX is probably the best beginner cycle out there. If you don’t destroy it when you get better, you can keep it as a freestyle unicycle as well. 20" or 24" is the best size to get started on. I’d go with the 20" though. It costs around $100-$120 where you get it. http://www.unicycle.com/shopping/shopaff.asp?affid=4 You can buy it there for a good price and a percentage of your purchase is donated to unicyclist.com
Hope this helped
thx but it also comes with tire choice what do you recomend
