Ok well I want longer cranks for my torker dx and I tried 150’s but they’re really annoying to ride around on. So I looked on udc and it says that they’re only available in 170mm. Is there anywhere that I can get the 145 mm?
so why are you looking for a quaxer hub?
do you mean the hub or cranks? the cranks are compatible with your current hub, so just buy the cranks off of municycle.com
The cranks are compatible with the DX hub, but there will be a little bit of a wiggle and they won’t fit completely right.
