Wheel Walk pre-skills
I’m starting to work on wheel walk, but being old I don’t want to kill myself. I have read that there are some pre-skills needed for this.
I’ve read one is one foot idle. I can do this one. But I also read that after that I should do something called a ‘wheel idle’.
I have been trying some things, but I don’t really know what a wheel idle is. What I am doing is placing one foot on the wheel and the other kind of hangs above the pedal.
What I am trying to figure out is what kind of stroke length do you need to do this. It seems almost like balancing on top of the uni, which isn’t easy.
So the other thing I read about wheel walk is that you need to do it slow, which is the reason, I guess, for the idling pre-skill.
Any advice?
the wheel idle you are talking about is:
one foot idle, but instead of foot on crown, you have foot on wheel.
This moves back and forth with your idling.
you then want to control the idle with your wheel foot, now, not the pedal foot.
(this is all theory…I got this response before, but have yet to use it…I can now one foot idle though, when I asked, I couldn’t)
David Winston gave a thorough explanation of wheel idling:
http://www.unicyclist.com/forums/showthread.php?s=&threadid=21393
Have fun,
Fred
Re: Wheel Walk pre-skills
I can ww a little, did it before one foot idling, and can’t do wheel idling,
which I had not previously heard of. Just practice whatever takes your
fancy. Pre-skills are indicators, not requirements.
For ww I started doing it with one hand on the wall. Hold onto something,
put your feet on the wheel, remember to lean back a little, go for it. You
should find yourself dismounting to the rear (or landing on your rear :slight_smile: ),
as
often as to the front, or you aren’t leaning back.
Doing it slowly just means you are in control of the wheel - you will often
find
yourself shifting your feet like crazy to keep up, and then dismounting to
the front, especially if you don’t lean back. That is not controlled.
I learnt to go from idling much later, and find this much more difficult to
get
right - my balance tends to be off for the first couple of ‘steps’.
Please define ‘old’.
Arnold the Aardvark - still can’t turn to the right in ww
‘old’ is when you look at what you’re about to try and say,
‘what the hell am I thinking?!?’
Just before “old” comes late youth/early old, which is when you look up at what you just Unsuccessfully tried and say,
“what the hell was I thinking!!??”
Youth is when you:
A) look up at what you just unsuccessfully tried and say,
“Cool! Let’s do it again!”
or
B) just do it the first d*mn time.
(I can prove this theorum using local Uni club members if you make me)
Thanks Sofa, and fred for the link to David’s great description. I guess that is the one I saw, but I think it was somewhere else.
I wonder why wheel idling isn’t in the list of skills. Maybe it is not well defined enough. My problem with that skill right now is that I don’t continue one foot idle after I put my foot on the wheel. I actually just mount into this wheel idle, with a finger against a wall or on the ceiling above for balance. But it look neat. It seems like a fun trick all by itself, and practicing doesn’t wear my leg out like idling does.
Now what is ‘old’?
Old is wearing full pads even for indoor practice because you reason that concreat is just as hard inside, and gravity is just as strong.
Old is not having or being able to rely on you parents to purchase your unicycle equipment, and, um, having to purchase such equipment for your own offspring.
Old is distinguished from ‘really old’ and ‘really really old’.
I’m young!!! :slight_smile:
> unicycle equipment,
I’m old… :frowning:
