How do you mount and then start wheel walking with out using the pedals? I
presume its possible. I just can’t seem to get on without making use of at least
one pedal.
And the latest news is I had my second go on a giraffe today, wierd things to
ride. I managed to freemount it after a few minutes. Seems you just got to throw
caution to the wind and go for it. Just watch the ankles when you don’t make
it:-) And definately watch out for the wheel skidding out from under you, not a
nice feeling!
Catch ya Peter
o Peter Bier - computing student o O o pjb10@waikato.ac.nz o(|\o
(delete nospam- to send a message)
<<How do you mount and then start wheel walking with out using the pedals? I
one pedal.>>
Way #1: Walk forward with the unicycle. Jump up and pull it under you at the
same time. Put your foot on top of the wheel to stop it, and have enough
momentum to keep going forward until you’re leaning forward and can start
walking (no, doesn’t usually work on the first try).
Way #2: Walk forward with the unicycle. Jump up, but this time put one foot on
the tire behind the frame. This stops the wheel rolling back while your momentum
carries you up & over. By the time you come level, pull that foot out of there
and start walking.
Don’t know which one is easier (neither, I guess).
The following mail header is for administrative use and may be ignored unless
there are problems.
IF THERE ARE PROBLEMS SAVE THESE HEADERS.
Reply-To: nospam-pjb10@waikato.ac.nz (Peter Bier) Precedence: bulk Sender: owner-unicycling@winternet.com Xref: paladin.american.edu
rec.sport.unicycling:4470 NNTP-Posting-Host: lab2-130.cs.waikato.ac.nz
Message-ID: <nospam-pjb10-1510972126390001@lab2-130.cs.waikato.ac.nz> Lines: 17
Organization: Student, Waikato University Date: Wed, 15 Oct 1997 21:26:39 +1200
Subject: wheel walk mount? Newsgroups: rec.sport.unicycling From:
nospam-pjb10@waikato.ac.nz (Peter Bier) Path:
auvm!paladin.american.edu!news.ecn.uoknor.edu!munnari.OZ.AU!
comp.vuw.ac.nz!news.hn.netlink.co.nz!waikato!lab2-130.cs.waikato.ac.nz!user To: UNICYCLING@winternet.com Received: from AUVM.AMERICAN.EDU (NJE origin
NETNEWS@AUVM) by AUVM.AMERICAN.EDU (LMail V1.2a/1.8a) with BSMTP id 9158; Wed,
15 Oct 1997 07:30:16 -0400 Received: from AUVM.AMERICAN.EDU by AUVM.AMERICAN.EDU
(IBM VM SMTP V2R2) with BSMTP id 2760; Wed, 15 Oct 97 07:30:15 EDT Received:
from auvm.american.edu(147.9.1.2) by icicle.winternet.com via smap (V2 .0) id
xma002952; Wed, 15 Oct 97 06:34:37 -0500 Received: (from adm@localhost) by icicle.winternet.com (8.8.7/8.8.7) id GAA02962 for <UNICYCLING@WINTERNET.COM>;
Wed, 15 Oct 1997 06:34:41 -0500 (CDT) X-Authentication-Warning: icicle.winternet.com: server set sender to owner-unicy cling using -f Received:
(from server@localhost) by icicle.winternet.com (8.8.7/8.8.7) id GAA03015 for
unicycling-outgoing; Wed, 15 Oct 1997 06:35:17 -0500 (CDT) Received: from icicle.winternet.com (icicle.winternet.com [198.174.169.13]) by thalia.fm.intel.com (8.8.6/8.8.5) with ESMTP id FAA17712 for
<JohnX_Foss@ccm.fm.intel.com>; Wed, 15 Oct 1997 05:06:58 -0700 (PDT) Received:
from thalia.fm.intel.com (thalia.fm.intel.com [132.233.247.11]) by fmm ail.fm.intel.com (8.8.5/8.7.3) with ESMTP id FAA18354 for <JohnX_Foss@ccm.fm.int el.com>; Wed, 15 Oct 1997 05:02:43 -0700 (PDT) Return-Path: unicycling-owner@icicle.winternet.com
Peter Bier <nospam-pjb10@waikato.ac.nz> wrote in article
<nospam-pjb10-1510972126390001@lab2-130.cs.waikato.ac.nz>… > How do you mount and then start wheel walking with out using the pedals? I > presume its possible. I just can’t seem to get on without making use
of > at least one pedal.
Well there is the kick up mount to wheel walk but that uses one pedal. Side jump
mount to wheel walk and jump mount to wheel walk are two that come to mind that
don’t use either pedal.
