the wheel is the 700 c Nimbus rim of my 29-er.
It’s never been entirely true, and it’s a close fit with the 2.1 tyre in a round Nimbus 28" frame; but it works without rubbing.
However it’s got a couple of obvious wobbles that it would be nice to straighten out.
The wheel is shimmed (at the bearing holders), without which it would rub, but that’s probably due to a slightly imperfect frame- I’m assuming that I should be able to get a true wheel with a shim in?
I’m OK with the right direction to turn the spoke key to tighten/loosen, and the basic theory.
I’ve located the wobble by a combination of spinning the wheel whilst holding a finger tip against it, and also a felt pen to mark the spots.
My problem is that at the point it’s being pulled in, the relevant inner spokes are already too loose for my liking, and the outer ones too tight.
i.e. logically it’s the exact opposite of what it should be!
In fact one of the reasons I’d like to get the thing truer is because of my concerns about the looseness of a couple of the spokes, but it seems I can’t tighten them because it pulls the wheel further out of true.
Is it possible that the wheels a lost cause?
Should I take it apart and rebuild it (I hope not!)?
Obviously I’ve got options as, like I say, it’s been this way for some time and seems to work ok; also I could take it to a bike shop.
But I thought I’d post this to see if anyone has had this can of illogical situation with wheel truing.
