okay it is a toss up between the onza…or the kris holms 2005 model?
I need a new trials uni that will hold up for good size jumps and all that stuff…thanks alot!
Tommy dizzle fo shizzle!
the KH and the onza hub and crankset are almost the same but the KH frame is lighter…so go for the KH.
well the weight difference is not that big of a deal…so for the cheapness I will just get the onza…thanks for the advice!
The kh and onza hub and crankset are the same. The only main difference is the weight. The kh has a better (wider) rim too. If you don’t care about weight then get the onza.
