Ok, I was thinking the crmo post would win but i would never think the classic would win.
how is it so strong?
I dont want the classic though, as it has no handle. Or could you buy a handle and put it on instead of that flat thing?
would the classic fit on the crmo seatpost?
are the bolts and all that included?
i just realised the handle wouldn’t fit. handles have 4 holes, seat has 2. also look http://www.unicycle.au.com/View.php?action=ProductDetail&Code=USITTR
its says steel and plast base??? it also says will fit any 22.2mm seatpost. i need the 25.4mm seatpost to fit my frame.
You will probably find that a Thomson seat post would be stronger than a cromo due to said “plate bending” but then you’ll need a rail adapter which are not invincible.
Best option if your made of money is a Thomson with a Wallis DeRail base, and a DeathGrip handle!
The classic saddle is pretty easy to toss a KH handle onto. I have a viscount (same as the classic I think) and I put a KH handle on it in a couple of hours.
How is the viscount without a handle? I know it has some sort of “lip” on the front and people are able to grab it for the handle effect. I belive shaun even did some big roll hops with it. Have you ridden it without the kh handle?
i could afford the carbon fibre, i have a job now, but i dont want to have to order it from germany or whereever. and also would that base probailer linked me to fit on the classic?
thanks bye
