do you guys usually put your tire Pressure at just wondering because I like to test some different ones out and see if it is a good feel, weird but just wondering, and why?
with your next unicycle related post please put it in the Rec.sport.uni
anysways just experiment if something feels to sloppy to lower PSI then pump it up and vice verca,
to answer your qusetion i run min aroun 23-27 PSI depending on what im doing and my weight is 55-58 KG
Actually, its not weird at all.
I do a lot of trials riding and some street, so I run my tire at 30psi. At that pressure its perfect because I dont bottom out when I land drops, and I still have enough spring off my tire to compress with.
For Muni I use the same pressure.
For freestyle I would pump it up as max as the tire allows.
Oh, I weight 170 pounds. =p
Sorry to be suck a dick, but you really should ask your question on ur title.
Anyhoo, depends on what ur riding:
Freestyle, high pressure
Muni, not too much, kind of in the middle.
Street, no clue
Urban trials, lowest presure i use (20-25psi)
Natural trials, very important to use more pressure because ur tire will fold on slants and wierd angle rocks. (27psi)
Hope that helps.
i ride around town on my uni or bike and in my backpack, i always carry a bike pump and some spanners (just in case).
