Does anyone know the weight of this frame?
And can you use it on a trials wheelset?
http://unicycle.uk.com/shop/shopdisplayproduct.asp?catalogid=672
I am not sure, although I will hopefully have it at Xmas so I will weigh it for you
Oh, and you can fit a trials wheelset in. Apparently you can fit an ISIS hub on it, and some people on the forums have, so I personally am going to take the risk…
Yea it works fine
Ok that’s cool, I’m almost certain that I’m gonna get it:D
The weight of the frame is 750g w/o the bearing cups and bolts. 875g w/bearing cups and bolts. It was at the bottom of the paragraph describing the frame on the link.
Pigs
I also have a round crown on my Isis wheelset and have had no problems with it.
Ah they have just updated the site: This frame has clearance to fit 20x2.5" tyre. Does not come with seatpost clamp. Weighs 750g (875g with bearing cups and bolts).
EDIT: woops, didn’t see that someone has posted it.
It says clearence for a 20x2.5 tyre, does that mean the monty tyre will not fit since it is 20x2.6? because I have already purchased the Monty Eagle Claw
What are both the nimbus 2 frames and the round crown frame made out of?
I just looked at my uni and it looked like it might fit, not sure though.
Steel
If you want to be sure about the bearings fitting correctly, you could try to get a hold of a Torker DX wheelset since they have 40mm bearings, although you then run into the problem of using nonstandard parts.
Oh, I don’t need to worry, It does fit an ISIS hub
I put my nimbus 2 frame on my dx wheelset, but i had to change the bearings.
Dx come with 40 as the nimbus needs 42.
I hate to be really fussy, but I would like to know since I need to send it back (if it does not fit) before the refund of 30 days
It only has a little over a quarter of an inch on each side of my Creepy Crawler, so I don’t think it will fit.
damn… okay, I will just have to wait and find out. You never know…
If not, expect to see a monty eagle claw on here after christmas!
i was trying to find the specs on the monty eagle claw…i think mine is a 2.5, do they come in different widths?? i’m fairly certain mine is a 2.5, and it’s probably at least a quarter inch narrower than my luna 2.5. if this is an indicator of monty sizing, you should be fine.
It says the eagle claw is 2.6 and a slightly higher profile than normal trials tyres
