According to unicycle.com the summit trials uni is 12 ounces heavier then the KH20. I was wondering where all that weight is. The only real differences between the two that I can see are the seat and the frame.
Another thing that struck me as odd, was that the KH20 uses 40mm bearing, and the Summit uses 41mm bearings. I assume that this means you can’t use a KH hub (with stock bearings) in a Summit frame. Am I wrong?
Re: Re: Re: Weight difference - KH20 vs. Summit 20
The Summit was an older prototype for the KH frame that the factory decided to sell on the side. The main reason I asked them to change to the current KH fork blade tubing was because of the weight, and because the KH tubing is slightly slimmer which reduces the overall fork width.
