Water Question.
Why is water wet?
It can’t help it.
But wait a while, and it’ll be dry again.
What will be dry again? :slight_smile:
Ice is made of water, right? But it’s not wet. Weird, huh?
warm ice is.
And water is wet because it’s a liquid. And it’s a liquid because of hydrogen bonds. And it has hydrogen bonds because of the hydrogen and oxygen. Hydrogen bonds form between hydrogen and oxygen, nitrogen and…fluorine I think.
Woot! Honors chemistry!
Water is wet because when you get it on your skin it starts to evaporate and you body senses the temperature change :smiley:
Ice doesn’t evaporate, it just melts :stuck_out_tongue:
Particle Man
When he’s underwater does he get wet? Or does the water get him instead…
Then how do you explain freeze-drying? Ice can evaporate given the right conditions.
Re: Water Question.
if u can tell me how long a piece of string is ill tell you why water is wet
String theory = infinite?
Did you know that water gets wetter when there’s soap in it?
I knew it can go from a solid to gas directly, I just meant it melts when you put it in your hand. :wink:
Ice isn’t slippery. It’s actually the thin sheet of water that melted on top of it that seems slippery.
Re: Re: Water Question.
Twice the distance from the middle to the end, now you have to answer my question.
Re: Particle Man
Nobody knows, Particle man.
If you put a candy coating over the ice, like an m&m, then it won’t melt in your hand. :smiley:
But it will melt in your mouth.
If you get ice in a 32/0 degree and below room it will be cold, but not wet.
