I really want to put a bottle cage on my stand. uni. I use it for almost all of
my transport. and work up quite a thirst. I have tried several approaches, but
all have failed. There seems to be no place fer it. I got little clamps to hold
the cage. I wanted to put it in the back (under the seat) on the post, but the
clamp is in the way. I now have it in the front but my thighs rub against it. Do
any of you have water bottles on your ikes? How’d ya do it?? Is there an
under-seat pack that will work with a uni seat? Suggestions would be greatly
appreciated.
vanraden@mail.erols.com wrote: > > I really want to put a bottle cage on my stand. uni. I use it for almost all > of my transport. and work up quite a thirst. I have tried several approaches, > but all have failed. There seems to be no place fer it. I got little clamps to > hold the cage. I wanted to put it in the back (under the seat) on the post, > but the clamp is in the way. I now have it in the front but my thighs rub > against it. Do any of you have water bottles on your ikes? How’d ya do it?? Is > there an under-seat pack that will work with a uni seat? Suggestions would be > greatly appreciated. > > Gwynneth the Mighty Squid (SemXL)
I got a cage with two tabs, and used strap clamps to hold the tabs down. This
has done the trick on my Semcycle XL. I have the bottle in back for the same
reason you want it there. I also squeezed in a cycling computer on the front.
Let me know if you need more details, and I’ll try to draw something up or
describe things better.
GV> I really want to put a bottle cage on my stand. uni. I use it for almost all
GV> of my transport. and work up quite a thirst.
There are alternatives. You could carry a bottle or two in a special
water-bottle-carrier belt. I’ve seen those in hiking supply stores. You could
even carry water on your back. Camelback water backpacks are sold in biking
shops. You’d drink through a long straw. No hands required, though for Unics
that’s less of an issue.
Seth Golub | “…And in all of Babylonia there was seth@cs.wustl.edu | wailing
and gnashing of teeth, till the
| prophets bade the multitudes get a grip on themselves and
| shape up.” - W. Allen
