Well, apparently my frame’s forks are a little off-kilter…I’m not totally sure how this happened, to be honest. They were fine when I rode over the Christmas holiday at my grandparents’ house, and after an 8-hour drive home, I tried to put my baby back together and the bearings on the wheelset were wider-set than the caps on my frame. Upon closer inspection, bent forks seemed to be the problem.
Whatever caused it is irrelevant (it was probably the suitcases sitting on the frame in the car on the drive home, or possibly the weather), but I’d like to know the best course of action to take at this point. I’ve tried just bending them out to straighten them, but I’m worried I ruin the crown-forks welding, cause I was already starting to hear a little creaking while I pull. Is there anything my LBS can do, or more preferably, that I can do (to save money)?
You are going to have to bend it back. I bent the forks on my qu ax frame so that I could fit a moment hub on it, the welds seemed to be fine.
If you are worried about the welds, maybe you should find a way to hold the frame together near the crown, and just bend more towards the bearing holders.
I dont understand why you cant put your wheelset in it, place one of the bearings in a bearing holder and bend the frork out while you push the other bearing in.
Should be ok to ride it like that, if you got it back on the wheelset. It might make something rub against the hub/frame, I’ve had that happen with a different frame before…
