I have a KH/Onza hub with 165’s, and I want to move to 150’s. It will be cheaper at this point to go ISIS. The hub just needs to be standard so that it will accept Moment’s, or qu-ax isis cranks.
Where are you? if you are in the UK you can buy my old KH hub, its pretty beeten up but it will be pretty cheap.
I’m in Longmont Colorado. It sounds like your hub would be perfect if it was just a little closer.
Thanks,
Jerry
You havnt seen my hub the flanges are pretty bent, kind of torn, im sure it would work fine. Nevermind.
actually, I was going to buy that for a no-cycle setup
