For some reason, my profile just got switched to German, all by itself (I wasn’t doing anything to my profile settings when it happened, even)
I can’t change it back, because first of all I don’t know were the languge settings are, and second everything says “Heute flobbenfhart” anyway so I can’t read it. Help?
Alrght, follow these and all will be well for you.
Click on User CP. This is the button on the bottom left of the two blue lines.
Go for the fourth option on the left hand side. In English it is ‘Edit Options’.
Scroll right down to the bottom and you should find the last drop down menu to have the gold you look for.
Mike
[EDIT] I have just followed these steps and they work fine… Unfortunatly, I was stupid not to check at the bottom of the page because, there is a drop down menu on the bottom of every page.
So. The drop down menu just to the right of the bottom left hand side has the answer to. DAMN!
Danke.
It’s fixed now… hmm, I tried the first thing you said (the long way) over and over, and each time I clicked on english it kept coming back in German… it wasn’t untill I went to the bottom of this page that it fixed it. Glitch Gilby?
