But i have a lot of video that is turned sideways. I was wondering, how do you rotate video? A program called “arcsoft” came with the camera, but it doesn’t seem to have anything that can rotate in it.
some help please? (i have some really good video to put up!!)
If the video is already in AVI format you can use VirtualDub. If it’s in MOV format you’ll have to first convert it to AVI format so VirtaulDub can read it. There is a link to a program that will convert MOV files to AVI files in the thread in Just Conversation.
Maybe try using Gallery Remote. There’s a link to it that you can see when you go to upload things. I use it these days and it’s pretty good for uploading a bunch of things.
Did you check the size of the rotated ones? VirtualDub doesn’t compress videos by default; make sure you’re not trying to upload a hundred megabyte file by accident. I’ve tried that before, it doesn’t work…
Failing that, I can’t think of why it shouldn’t work… strange…
…Ryan, in my opinion the “three sixty - footplant video” is the best of it all. And to make a sidehop with 85cm…very impressive. I think it is nearly worldrecord
