Just a quickie to show this new kind of mount I came up with for a 36er; I call it the “Pull up chest mount”. It may have likely already been done on smaller wheeled unis, but I like it because it’s fairly easy to master, and is quite a stable type of mount!
You basically tilt the uni back about 45 degrees, lean forward and put your chest on the saddle, then using both hands, hold onto the tire with one hand in front of the frame, the other in back to “lock” the wheel. Then roll yourself (forward) up over the top to CG, at the same time putting both feet to the pedals at the same time! Then roll away!
There’s a couple other mounts and I try a 270 hoptwist on my 36er! Check it out.
