I did and I made some drawings while she looked on, so when in doubt, try it out, which is what I did
Seriously, there is nothing like testing a theory, because we are often misled by what we have learned, make assumptions, etc…
When I found myself sitting on the waist of my flat seats and had to use an upturned saddle to push my pelvis back on the seat, I realized that there was more to the formula than simply flattening a seat.
Today, I built up the waist of a seat so the wider portion of the seat was carried forward. I found that I was now sitting on padding and balancing in the sweet spot; the waist. Essentially I had moved my pelvis forward on the seat without relying on an upturned saddle to hold me in place.
Now whether a forward shifted seat post or a rearers shifted seat base mount would do the same, that’s the harder theory to test…so I’m starting work on bike seats tomorrow…
But first things first: Can you all measure the distance between your IT (sit bones)?
I measured mine at 110-115mm. I wonder if this is wider than average, which would explain why some folks are more comfortable on a stock seat. I’m not a huge guy by any means, but I have some good birthing hips
The KH Freeride base is 135mm wide, the Freeride foam is 150mm wide (note that it rounds over the edge at ~ 125mm.
I measured a bunch of mountain bike seats, all had a similar width to the KH seat, ~150mm.
A “comfort seat” we have mounted on a spin bike was a whopping 190mm wide (rounding over at ~ 170mm) and it was so much more comfortable to sit on when I was upright, whereas the bike seats felt a lot like a unicycle seat; just wide enough to work, but not wide enough to be comfortable.
It appears that my “arse bones” are too wide for a uni seat. Even with flat foam I only have ~10mm of foam on either side, which is why it feels like my ITs are sitting on edges of the seat; because they are! The problem is even worse when I sit on the waist of the seat, because then my ITs are not supported at all!!
I wonder if the reason uni seats are narrow, other than mimicing bike seats, is so that it’s easier to dismount to the rear? Not that adding 40mm would make a huge difference, but it would be harder to get your legs around the seat as you dismount; I tend to get off forward, so not a problem for me
I like playing with gear, esp making new stuff out of old stuff, it’s like McGuyver or something
