Used inner tubes?
Whenever I have to get a new tube for my uni or bike, I don’t like throwing out the old tube, cause it’s a lot of good rubber. So, I like to think of things to do with them. :roll_eyes:
I’m devoting this thread to coming up with good/creative uses. I’ll start off, most creative answer gets +1000 points.
  1. Cut cross-sections make good rubber bands.
  2. Great slingshots. :sunglasses:
  3. Padding for my muni frame so my boot eyelets don’t scratch it up.
  4. They sound cool when you blow them up and they explode. :stuck_out_tongue:
Using as patches for puncture repairs.
T.
inflate them and make ballon animals?
or just oddly lump a bunch together and call it modern art.
hahaha :smiley:
you could use them to make a pattern in the holes of the frame…like the koxx
rim…i think :stuck_out_tongue: :smiley:
Im with Darktom, I use mine for spare patches instead of buying new tubes. Although, the tube would have to be pretty f**ked before I would cut it up, I try make the most of them!
Rock on!
Edd
Yeah, I patch all my flats. I only replace a tube if a patch fails and screws up the tube, or if the valve goes bad.
Oh yeah, and +500 points for most practical.
Nice one!
T.
Resistance workouts. Step on one end of the tube, then do curls / butterflies with the other. Tie one end to a tree and do pull downs / crunches / kicks. ROCK HARD ABS in 6 weeks or your money back, GUARANTEED!
get a car inner tube and blow it up
sit in it and go down a river!!
I’ve been told they are great for starting fires… :astonished:
Ha ha! Good one…Scrunchies! Some of those…things you put on your glasses so they don’t fall off…Am I the only one who wears glasses around here?
3 man water balloon launcher
water hose
pop gun(inginuity required)
Uh…Giant shoelaces!
i have scraps of old inner tube all over my unicycles. mostly in places where i don’t want metal touching other metal. between my black seatpost and some hose clamps, for example. i also use them as shims in various spots.
I use them as loose junk to make my bedroom look messier.
Two friends of mine take their old tubes. cut them down the middle so it becomes a long flat section of rubber, and then they line their tires with it.
someones been watching their Macguyver
You can actually use a cut of the old tire itself to do this, especially if you get “bubbles” where the tube splits out from the time.
They are keeping secret the fact that they have invented a permanent innre tube that NEVER needs to be replaced. It can never be punctured.
The inner tube industry is keeping this a secret from you.
Not only that, but nearly 30% of land fill space is now occupied by inner tubes, because they are not biodegradable.
5% of the space is disposable diapers.
What, solid rubber? I think that leaves the realm of pneumatic tires… :roll_eyes: :smiley:
