unispin's
how do you jump off your unicycle when attempting these?
im starting to get into freestyle some, plese help me out here.
jump off evenly. did you see the recent video i posted when trying a 360 unispin and my foot wassnt even and i fell ? it sucked. obviously try 180 nispins first lol. and go for the cranks. wear shin guards, spin fast, and dont get scared. dont get upset either. im up to 1200 consecutive failures on 360 unispins,and im still trying. and it took me 2 months (about a yr ago) to land my first 180 unispin. unicycling sucks, so be persistent. im drifting so ill stop.
don’t pick the unicycle off the ground…make sure the tire is in contact with the ground the whole time. this will prevent the pedals from moving too much so the pedals will still be level when you try to land it.
when you jump off, pull your legs up and move them to the outside, then pull them back in really quick to land it.
It also helps if you do it on perfectly flat ground. If you’re on a slant or bump then one foot will push down harder than the other and the pedals will end up in the wrong orientation.
I found it helps to first try in grass. That removes some of the fear of missing the pedals for some reason.
