Unicycling Resolutions -- Levels Based
Whoa. I suck. I just realized I’m a level 1. :astonished: That’s only because of this:
Level 2
√ * mount with left foot
X * mount with right foot
√ * ride 10 meters between two parallel lines 30 cm apart
√ * ride a figure eight with circle diameters smaller than 3 meters
√ * ride down a 15 cm vertical drop
√ * make a 90 degree turn to the left inside a 1 meter circle
√ * make a 90 degree turn to the right inside a 1 meter circle
Oops. I’ve never even tried. Adding to my list of resolutions …
As for Level 3 …
2/3 * demonstrate 3 types of mounts
√ * ride a figure eight with circle diameters smaller than 1.5 meters
√ * come to a stop, pedal half a revolution backward and continue forward
√ * ride with the stomach on the seat for 10 meters
X * make a 180 degree turn to the left within a 1 meter circle
X * make a 180 degree turn to the right within a 1 meter circle
√ * hop 5 times
√ * ride or hop over a 10 x 10 cm. obstacle
Hmm. All of those are never trieds …
Can’t do any level 4s. Well. New resolutions I suppose.
-EDIT-
Wait. For the 180˚ turns, can you hop and turn? Or do you have to like pirouette? Because if it’s a hop I’m all set.
you must stop, and then make a sharp turn. Hop-twists don’t come in till level 7.
my resolution is by next year to be level 8 and up
I haven’t taken a good look at the levels in a while. I feel like they are kinda inaccurrate ratings of a rider. I want to learn how to 360 unispin ASAP! I’m so close. Thats really it right now. Learning how to glide would be cool too.
thats a possible goal, but you will be bored of it by the time you get there
Level 11.
Ditto! :roll_eyes:
