Just a little note that I just updated my megalist of bookmark links. Added some new links and did a little bit of reorganization.
As if anyone cares.
As if anyone cares.
Okay, other than going to each link, and adding them to my favorites, is there a way to just add the whole list?
Also, that list is unbelievable!
Right-click on the links to save the bookmark files to your local computer. Youāll have two files: cycle_bookmark.htm and unicycle_bookmark.htm
Then import them to your browser.
In IE you go File >> Import and Exportā¦
In Firefox you go Bookmarks >> Manage Bookmarksā¦ then File >> Importā¦ and select import from file.
I can feel my productivity plunging as i type! Thanks!
Wow dude, thatās rad! You did all that by yourself? Itās gigantic! Any idea on the total count there?!
I didnāt hink it was possible, but you missed one.
Youāve been added and the Megalist has been updated.
Iāve missed others too. The trick is finding them.
Iāve been looking for a web site for the Filipino Unicycling Network (FUN) unicycle club. They must have a web page but Iāve been unable to locate it.
Thereās a little under 1000 links in the unicycle section, but 400 of those are gallery links (links to galleries Iāve downloaded pictures and videos from).
The bike section has about 250 links. Donāt ignore the bike links just because theyāre not unicycles. Thereās good links in there for info on trails and equipment.
Iāve been collecting unicycling links since I started surfing the web (a long time ago). Iāve also gathered links from other link collections. Others Iāve found on my own. The big job was finally organizing them. Once they were somewhat organized I figured I might as well post them.
I was trying to import this to my new Laptop, and it says itās not a valid bookmark file. Any idea what I am doing wrong?
I think I see what the problem is.
Gilby adds a line at the beginning of the page to add the graphic that says āThis is a free unicyclist community websiteā. That line is likely messing up the import. Open the HTML file in a text editor and remove everything before the line that says:
<!DOCTYPE NETSCAPE-Bookmark-file-1>
That DOCTYPE line should be the first line of the file.
Save the edited file.
The file should now import.
With such a massive amount of linksā¦ you might want to keep them accurate.
In case you donāt know it allready; w3c.org has a webbased link checker which source is available.
Iāve been using AM-DeadLink to identify the dead and redirected links. There are some dead links and redirected links in the list. I just havenāt gotten around to following up on all of them.
So, what about dumping them in a MySQL database, so you can easily maintain the list? With a simple webbased interface. (that can be connected with an āadd link formāā¦!)
Then it also it could have a RSS feed with both a ādaily linkā and āupdateā entries.
And with some manipulation in the .htaccess i.c.w. php you can also spit import files.
Just e-mail or PM me in case I can be at your service.
missed twohttp://www.freewebs.com/southfloridaunicycling/
Now i know it not the best but thats because we havent had many meetings.
Got ya now. Thanks for the link.
I donāt have any plans for the links. I just had a bunch of semi-disorganized links. I finally got around to organizing them and when that was done I figured why not put them on the web to share.
The link list is just an exported bookmark file from IE. Thatās probably as far as Iām going to take it. However, the future is open.
