Hello ! I am wondering if unicycle tricks are easier to learn in correct order. Can somebody write a list of his first tricks in right order * 10 tricks/ at least. U can certainly write more or less.
I learned different kinds of mounts first becuase that leads you to different things.
- Static Mount
- Side mount- 2 wrap around side mount- 3 wrap around side mount- side mount while riding
- Jump Mount- Suicide Mount
- 180 unispin mount- 180 unispin- 360 unispin
Then once you’ve learned all those mounts I would try learning to go backwards and learn to idle. But from there on out I have no experience.
The gliding and one foot idle(etc.) is up to you.
The simple answer to your question is ‘no’. Doesn’t really matter what order you learn tricks in - just whatever you want to learn, have at it.
Try to master the riding first, learn backwards and one footed before trying to do all the fancy street tricks that have been popularized lately. Once you get better at hopping go for all the other stuff. Just do it!
The order I learned in:
riding forward
freemounting
stalling/standing still
idiling
riding backwards
1 foot riding
jump mount
1 foot idiling
180 jump mount
everyone is different though as a rule of thumb I think its a good idea to learn to ride before you concentrate on the mounting. Whats the good of learning to freemount if you cant go anywhere once you’re on
There isn’t at all a correct order, but most tricks/skills are proggressive, such as gliding or seat drags.
for example:
to learn to glide-
learn to wheelwalk
learn to one-foot wheelwalk
one foot wheelwalk downhill and try to glide for short bursts
try a slightly steeper hill and transition directly to gliding
finnally, try gliding on flat.
i learned in this order. took me about 2 months
freemount
forward riding
hopping
jumping up curb/steps
jump mount
suicide mount
180 jump
rolling hop
1 footed riding
and i am currently working on
wheel walk
backwards
idling
i want to do 180 unispin but am not very good yet
seems to me you can learn in any order you want.
dont listen to them, do the levels first-http://www.unicycling.org/IUF/levels/
Up to at least level 5, that will take you a while, once you have mastered the main things, like hopping you can move onto the street levels…
Skill levels
[edit] Level 1
Rolling hop down a curb
Rolling hop up a curb
Ride forward down a 2-stair.
180 hoptwist (static)
[edit] Level 2
Ride forward down a 4-stair
Rolling hop down a 2-stair
180 hop twist (rolling)
Tire grab (static)
[edit] Level 3
Ride forward down 6 stairs
Rolling hop down a 4-stair
Backwards rolling hop
180 hop twist down 2 stairs
leg around (static)
Crank Stall on a ledge (like a crank grab but not going to rubber)
No footer (static)
Tire grab down 2 stairs
Ride with seat out
Hop with seat out
[edit] Level 4
Rolling hop down a 6-stair
Backwards rolling hop off a curb
Rolling 180 hop twist down a 2-stair
No footer (rolling)
Shifty
Grind a 1 meter ledge or rail
180 unispin (static)
[edit] Level 5
Backwards rolling hop a 2-stair
180 hop twist down a 4-stair
Rolling hop down a 3-stair with right or left foot forward
Grind down a rail
Rolling hop up a 3-stair
Shifty down a 4-stair
180 unispin (rolling)
[edit] Level 6
360 hop twist down 2 stairs
backwards rolling hop a 4 stair
No-footer down a 2 stair
180 hop twist to the right down 6 stairs
180 hop twist to the left down 6 stairs
Rolling hop up a 3 stair
crankflip
360 unispin (static)
180 unispin a 2 stair (rolling)
[edit] Level 7
backwards rolling hop down a 4 stair
crankflip down 2 stairs
backward crankflip (riding forward, and then crank flipping backwards)
Hick or outflip a 2 stair
rolling hop up a 4 stair
grind a handrail of any size
[edit] Level 8
backwards rolling hop down a 6 stair
backwards 180 hop twist down a 2 stair
360 hop twist to the right and left down 4 stairs
180 hop twist to the right and left down 6 stairs
crankflip down 4 stairs
backwards crankflip down 2 stairs
backwards backward crankflip (riding backwards and flipping the cranks backwards)
backwards forward crankflip (riding backwards and flippimg the cranks forward)
Hick or outflip a 4 stair
360 unispin(static) a 2 stair
grind a 6 stair handrail
[edit] Level 9
backwards 180 hop twist down a 6 stair
crankflip down 6 stairs
backwards crankflip down 4 stairs
180 crankflip down 2 stairs
hick or outflip a 4 stair
Treyflip a curb
[edit] Level 10
backwards suck hop down an 6 stair
360 hop twist down 6 stairs
backwards crankflip down 6 stairs
180 unispin crank flip down 4 stairs
180 crankflip down 4 stairs
360 unispin crankflip(treyflip) down 4 stairs
180 unispin(hick/out-flip) a 6 stair
grind a 6 stair hand rail
shifty
The rough order in which I learnt what I can do:
Forwards
Mounting
Hopping
Idling
Backwards
1 foot with left foot
Rolling mount
180s
Seat-out hopping
Jump mount
Suicide Mount
1 foot with right foot
1 foot idle
WW
1 foot WW
Grinding
Glide
The unicycling skill levels are a good outline in which to follow, but if you feel like you’re getting the feel for something that is a level 4 item and you haven’t yet learned to do one of the unrelated level 3 items…just go with it. Everyone learns at a slightly different pace and order. Just dont attempt a backwards figure 8 one foot wheel walk before you can ride straight for 10m
yea I didnt learn seat on the stomach till level 5 (though I hadnt tried it either…) I did these levels untill I came to unicyclist.com by that time I was doing stuff from level 8 (piroutte) to 10
funny you should mention the riding on stomach bit. Thats exactly the item I had in mind when typing that as I did the same thing. I actually had a GB4 handle on my only unicycle when I was at that level so riding on stomach put my neck in the path of the forks if I UPD’d forward so I just didn’t learn until I got a freestyle cycle.
