Hey. I have some stuff for sale.
I have some pedals, I guess. THey are black, plastic, and basically new. I have never mounted them on a crank arm ever. They can be $8.
There are also come crank arms. THey are both 125mm and cotterless (the best crank arm setup in the world, btw) THey have some surface oxidation, which makes them look amazing. or not. They’ll be $10.
I also have a 20x1.75" rim. It has 36 holes and is double walled. The model is Weinmann safety line DM 30. It works well. It will go for a whopping $20.
I also have a seat, frame, seatpost, and double bolt clamp. They are all the 22.2 size. I think the post is 150mm long, but I honestly don’t know. The frame is for a 20 inch wheel, or a trials wheel, but it has the bearing size for a cotterless hub. $50 for that whole set up.
If you want close-up photographs of anything, I’d be happy to post them.
