Unicycle Harness?
Just following on from the Gliding and Backflips conversation,
Has anyone made a harness for unicycling that allows backflips and such tricks.
I thought about drilling holes in the seat bace and putting metal hooks which then might be used to fasten a harness to.
Id really apreciate the responce
Trev
use a figure skating harness.
Back flips
When we use a harness in figure skating it is for verticle rotation only. The cross bar over your head would probably stop all your roatation when you hit it half way threw.
We do teach people to do back flips on ice, but its way lower tech than a harness. Take 2 sweatshirts and 2 friends. Get each one of the freinds to wrap a sweatshirt around your waist from both sides of you. One on the left side, and one on the right. They can use the sleeves to hang on to. If they walk beside you as you attemp the back flip they can pull on the sleeves and that will act as a harness. Its like doing one of those parallel bar flip things were your holding the bar at your waist and then flip around it. This sounds hokey, but it really does work.
