Such a “seemingly” simple trick, but no takers!!!
A few years ago, I put out the request to do this:
Trick 1: A “clocking” bunny hop.
How to do:
a.) Bunny hop
b.) Simultaneously, start rotating the cranks like a clock.
c.) Rotate an hour at a time. Not a “crank flip”, although that’s probably 2x harder…this should be so easy for you crank flippers.
The mechanical difficulty or trick is:
-the ability to maintain equal pedal pressure at different “clock positions”
-it’s easy to freeze and hold the 3 & 9 o’clock position with equal pedal force, but try that at left pedal at 12 o’clock and right pedal at 6 o’clock and every position in between.
Impossible? Okay, here’s slightly easier:
Trick 2: A 6 & 12 o’clock pedal position bunny hop.
Just channel the power of the “easter bunny”
…slam!
