I loaded up the box of Pins in a bike trailer (no bike of course), just pulled
it along in my hand, quite difficult to gain the extra momentum.
At first I tried the standard triangle but the pis were too close together, and
I tripped over the fallen pins, after spreading them them a part I bit I could
ride between the lines knocking about 8 pins on each run. With some better
hopping, turning, backward ability someone could proabably pick up a strike and
ride away.
After I tried some slalom first trying to not knock over the pins then trying
specifically to knock over the row of pins swirching sides beteen each.
If I weren’t riding the train I’d bring them to the NUC, I know all of you could
find some fun uses for them.
They would also make good pick up off the ground objects
… > At first I tried the standard triangle but the pis were too close together, > and I tripped over the fallen pins, after spreading them them a part I bit I > could ride between the lines knocking about 8 pins on each run. With some > better hopping, turning, backward ability someone could proabably pick up a > strike and ride away.
Another way to do it (requires a bicycle): If you still have a bicycle,
Put up the pins, get on your bicycle ( wooah… strange feeling , start riding
on your rearwheel, remove you frontwheel while still riding, throw it at the
pins! and ride away…
that’s it… not a strike?.. so what… just ride away with your new uni…
GeGgAkLaBB Ge Kenny Johansson O BB Gg sven2@algonet.se
/|\ La Ak pgp-key: URL below O Ak La
<a href="http://www.algonet.se/~sven2">http://www.algonet.se/~sven2</a> Gg BB +46(0)383-730262 Ge
