Re: Unicycle approach to MTBking?
In article <U-Turn.mku1n@timelimit.unicyclist.com>,
U-Turn <U-Turn.mku1n@timelimit.unicyclist.com> wrote:
)Your statements, Tom, are of the form “No, it’s not!”. I haven’t heard
)anything that would speak to a unicycle being less efficient. A bicycle
)may have a nicely lubed chain, but a unicycle doesn’t have one to lube.
)The aerodynamics are worse on a unicycle, but at low speeds is probably
)not a factor. The wobble of the wheel, like non-circular pedaling on a
)bicycle, is a matter of less-skilled unicycling, not a “force to
)overcome.” In what way does a bicycle “use its momentum”? Finally, what
)does gearing have to do with efficiency? We have to define terms
)better.
My statements are of the form “no it’s not” because the problem really
seems too obvious to be worth arguing. But if you insist, let us
define “efficiency” in this context as a measure of the ratio of
ground speed to energy input. A person who can go 10 kilometers per
hour while expending 300 calories per hour is operating more
efficiently than one who goes 10 kilometers per hour burning 500
calories per hour, and a person who can go 20 kilometers per hour
while burning 300 calories per hour is operating more efficiently than
one who goes 10 kilometers per hour while burning 300 calories per
hour.
I am not a particularly fast bicyclist. I can ride 100 flat
kilometers in 4 hours, for an average speed of 25 kph. If I were to
do a fast 4-hour unicycle ride, I would be at least as tired (burn at
least as many calories), and realistically would be more tired than I
was after the bike ride. And there is no unicycle in the world which
would take me anywhere near 100 km in 4 hours.
I do not think it is a great leap to assert that this is true for all
reasonable values of “bicyclist” and “unicyclist.” If you want to
trot out the fastest unicyclist in the world and say he could do it, I
get to trot out Lance Armstrong and point out that he could go twice
that far on a bike.
All unicycle wheels wobble, all the time. Experienced unicyclists wobble
less, but they still wobble visibly–just look at the tracks one of them
leaves. That curvy track represents energy constantly being injected
back into the system.
A bicycle “uses its momentum” in the sense that if you suddenly stop
putting energy into the system (stop pedaling), the bicycle will tend
to continue moving forward with only incremental speed loss. (OK, if you
want to be pedantic, there is still energy being expended to balance the
bike, even if you’re not pedaling, but it’s miniscule). If you suddenly
stop putting energy into a unicycle–if it were even possible, which it’s
not–it would almost immediately fall over. Just try coasting with no
feet on the pedals and see how far you get–even Sem can’t do that for
any distance.
Gearing has to do with efficiency, as I’ve defined it above, because
for a given power output, it will be more efficient to be in a certain
gear, and what’s more, more efficient to have multiple gears to choose
from.
-Tom
