Unicycle 4 gears hub project
I love those pants they look like custom unicycling pants. Maybe another innovation in the making.
Next delivery to be received
is it bad that I immediately see happy chubby faces when I look at them?
From first ride to 5 prototypes in the wild in a week is astonishing progress!
I’m curious, have you thought of a name for the hub yet?
Yes, might be fun to pronounce for a non French
I’m thrilled to see that this long-running project has now resulted in actual working prototypes! The four gear ratios are an incredible proposition, and the steps between them are quite nicely/evenly spaced. The ability to shift by hand is appealing to me, because even after 20+ years of Schlumpf riding, the gear shift has often been hit-and-miss for me. I don’t see in the photos (nor do I understand) how the gear shift cables can connect to the rotating hub, but apparently it works.
Very interested in seeing the next steps, hopefully leading to it being commercially available.
Big kudos to you Didier for your perseverence!
I guess only the outer part of the hub shell is rotating.
So cool!
Exactly with very big and thin bearings
congrats! an other huge step in unicycle history!
It’s pretty much the same with Rohloff, and this bearing setup even works on downhill rides. I think it’s a good choice to do it this way.
I know it is a bit early to ask, but the 2 recessed screws on the group picture made me think of it: will it require topping off the internal lubrication? If yes, will it be a similar grease as the Schlumpf or a more common one?
those 2 screws are there to connect both sides of the hub. There is another specific black screw on this same side to feed the lubricant
A quick look back at my time at the French Cup CFM 10 days ago where I presented my 4-gears prototype.
Following the very positive feedback from the very first tests carried out a week before the CFM, I decided to come and present it there.
I arrived on Saturday afternoon at the start of the CFM, and it was a pleasure to see some familiar faces I hadn’t bumped into since I took part in Unicon Grenoble 2022 as a volunteer.
My prototype was tried out by a great many people and the feedback was overwhelmingly positive, even though it had only been ridden for just over two hours beforehand.
Simon Jan, Timo Hirschman, Martin Charrier, Aurélien Paulmier and Maxence Cornaton, in particular, were also able to share their comments on the prototype with David and Jean from Effigear – the company I’ve been working with for three years – who’d made the trip specifically from their offices to get to know the unicycling community better and see the result of our joint efforts.
The feedback highlighted some excellent points regarding the quality of the gear changes – which were very smooth and almost instantaneous – the small gap between each gear, the ease of changing gears using the twist grip, the minimal play in the mechanism, the moderate overweight compared to a Schlumpf, as well as the prospect of being able to ride with a gear ratio of 1.72 on future prototypes with a view to attempting a few world records, in addition to the base version at 1.53 on this first prototype (almost identical to the 1.5454 of a Schlumpf).
But before that, there are a few areas that need improving and others that need fine-tuning to ensure we have a fully polished product – and we’re already working on these.
See you very soon for the next instalment of this exciting project, which could well become a future game-changer.
Didier / Bouin-Bouin
