uni wheel in truing stand
Kinda urgent, is there a way to properly true a wheel in a park ts-2.2 truing stand? I had originally thought about resting the isis splines in the fork legs but am no longer sure that’d work.
For reasons I don’t want to get into, I’d like to avoid doing this in my frame and don’t have the kh adapters for the stand so I need to know if anyone has made this work.
Thanks.
Maybe a couple of “live centers” for a lathe, one on each side. The shaft would go into the notch on the stand, and the cone would go into the end of the spindle.
Maybe easier to use a 42mm hole saw in a piece of hardwood, and screw it into each side of the stand. Or even easier, make them into v blocks.
I’m sure you can make these work somehow.
As mentioned from the chinese unicyclists the cheapest truing stand is a unicycle.
  1. To fix the unicycle upside down on the floor, remove the saddle and screw the seat post on a sheet of wood.
  2. Lower the seat post until it scratches the rim and start truing.
Just look at the two pictures.
I just wind the arms in so the bearings sit “inside” the top of them. I might have a pic from building my wheel yesterday using a stand that’s very similar…
EDIT: Nope, deleted it off my phone
So do you put the arms between the bearings and the flanges of the hub?
Killian:
What about hacking the ends off of a cheap uni frame, crushing the tubes in a vise, drilling and mounting to the TS2?
Or, if you have some bearing caps left over from installing a couple of D-Brakes you can screw those to a piece of wood, and mount that to the TS2.
This will work. Thanks!
