Ultimate Wheel Questions
Hello,
As a project for an engineering class I have to improve some existing item.
I'm looking into how the ultimate wheel might be improved. If anyone out
there with UW experience can give me any suggestions about what could be
improved on the existing ultimate wheel, I would be very appreciative. I'm
already considering the following:
* leg abrasion
* side to side rocking
Thanks a lot,
George C. Barnes IV President ISU Unicycling Club
Re: Ultimate Wheel Questions
What about a nonplanar wheel? Could we devise some odd-shaped wheel that would
be easier to keep upright because the contact patch on the ground would always
be where most of your weight is likely to be?
So which ISU are you talking about?
Chris
“George B.” wrote:
> Hello,
> item. I’m looking into how the ultimate wheel might be improved. If anyone
> out there with UW experience can give me any suggestions about what could
> be improved on the existing ultimate wheel, I would be very appreciative.
> I’m already considering the following:
> * leg abrasion
> Thanks a lot,
RE: Ultimate Wheel Questions
> about what could be improved on the existing ultimate wheel, I would be very
> appreciative. I’m already considering the following:
> * leg abrasion
How about a seat? :slight_smile:
I just wonder if the ultimate wheel is something one would want to improve. It’s
supposed to be hard to ride, either as a part of an entertainment event, or for
exercise for someone like George Peck.
For a simple improvement, it might be nice to find out the optimum pedal
distance from wheel center (crank arm length equivalent). I don’t know if longer
or shorter makes it easier to ride.
Any thoughts on this?
Good luck George. George is from Iowa State University.
John Foss, the Uni-Cyclone jfoss@unicycling.com www.unicycling.com
“Dad, I’m hypo-icecreamic.” – Woody Hooten, at the end of a long MUni ride
(Woody’s mom is a doctor, and this sounds like something his family developed on
long car rides when the kids were young)
Greetings
In message “RE: Ultimate Wheel Questions”, John Foss wrote…
>> * leg abrasion
>It’s supposed to be hard to ride, either as a part of an entertainment event,
>or for exercise for someone like George Peck.
>longer or shorter makes it easier to ride.
I once experimented considerably with wheel size and crankarm length. I even
built an UW with an extendible cranklength. I am sure that ultimately this
depends on personal taste, leg length, and the like. For me, I found that a
24" UW with a
5.5" crankarm is the easiest to control.
>on long car rides when the kids were young)
Regards, Jack Halpern President, The CJK Dictionary Institute, Inc.
http://www.cjk.org Phone: +81-48e$B!]e(B473e$B!]e(B3508
If your project is successful you’ll end up with an UUW.
Klaas BilOn Fri, 6 Apr 2001 15:22:23 -0500, “George B.”
<gbarnes82@hotmail.com> wrote:
>Hello,
> I’m looking into how the ultimate wheel might be improved. If anyone out
> improved on the existing ultimate wheel, I would be very appreciative. I’m
> * leg abrasion
>Thanks a lot,
“To trigger/fool/saturate/overload Echelon, the following has been picked
automagically from a database:” “Lockerbie, minister, Abdelbaset Al Megrahi”
In my opinion, taking the post off and riding the Coker Ultimate Wheel is much
easier to stay on than a smaller wheel. I think a larger version (or heavier
wheel version) would increase control considerably. -chris
“Jack Halpern” <jack@kanji.org> wrote in message
news:200104071309.AA12417@mail.kanji.org
> Greetings
> >> very appreciative. I’m already considering the following:
> >> * leg abrasion
improve.
> >event, or for exercise for someone like George Peck.
if
even built
depends on
> personal taste, leg length, and the like. For me, I found that a 24" UW
with a
ride
> >developed on long car rides when the kids were young)
> * leg abrasion
Try making the planar support about 1/8" thick with pedal screw holes flush on
the pedal side and sticking out 3/8" on the other side (covered by a contoured
cover so the leg can easily slide over it. This is to get the feet as close as
possible to the side-to-side balance point.
Also, try different width wheels from 1" through 3" and different shapes of tire
cross sections from round through virtually square.
Good luck!
Sincerely,
Ken.
Greetings
In message “Re: Ultimate Wheel Questions”, Chris Carey wrote…
>is much easier to stay on than a smaller wheel. I think a larger version
>(or heavier wheel version) would increase control considerably. -chris
You are probably right, but the heavy weight may be difficult to control.
Did you try it?
