Tyre pressure
G’day
I am new here so forgive me if this has been asked before.
How much pressure do I put in my tyre.
Nimbus Signature 20" trial.
It is brand new and totally different than the old skinny wheeled 20" that I have been learning on.Is it better to have alot of bounce in the tyre by having a lower pressure or does that run the risk of damaging my rim???
thankyou for your time
harro
Tire pressure has already been talked a thousand times on the forums. Use search fontion next time before creating a new thread.
Tire pressure is just a preference, dont ride with too low pressure to hit the rim, but you may not want to ride with a too high pressure so you can get some bounce from your tire. Just try different pressure and you’ll find the right one for you.
If you want to be able to do some basic tricks and hops, decrease the tyre pressure bit by bit until the tyre is slightly bouncy but not very bouncy. If the tyre pressure is too low than you could damage your rim if you do jumps of big obstacles (1 meter+) I am 15 years old, around 65KG and I have about 24 PSI I think.
