Tube talk...
>At 06:58 08/02/00 GMT, Chris Reeder wrote:
>>Also, the tire shifts on the rim some when I ride it, so that the valve
>>stem is now angled about 30 degrees off of perpendicular. Does this happen
>>to any of you?
>Yes, this happens to me sometimes. I shift it round asap so the base of the
>stem doesn’t get worn through.
It sounds like you’re using the “schrader” (sp?) type valve, the kind that
comes standard with many bikes and unicycles. I would recommend switching tube
styles to “presta” valves (just about any good bike shop will have them.)
They’re a little more expensive, but worth it. They have a steel shank that’s
threaded, with a lock nut to tighten it into the rim. As long as the lock nut
is tightened, it can’t slip. Besides, with a steel shank, you can’t wear
through it anyway.
Tim B.
Re: Tube talk…
>>>Also, the tire shifts on the rim some when I ride it, so that the valve stem
>>>is now angled about 30 degrees off of perpendicular. Does this happen to any
>>>of you?
>through it anyway.
Note that the hole for a schrader valve stem is bigger than one for a presta
valve stem, so special mounting hardware might be needed to keep the presta
valve from moving in the bigger schrader valve rim hole.
Sincerely,
Ken Fuchs <kfuchs@winternet.com>
Microsoft has finally found someone it can’t bully into submission: US
Department of Justice - http://www.usdoj.gov/atr/cases/ms_index.htm Yahoo links
