Hi all,
I just bought a Schwalbe Big Apple 28x2.35 tire and I’m looking for a tube.
What is the size of the tube I should use?
Thanks for your help.
Hi all,
you need a 29er sized tube,somthing like a 700x52
Re: Tube size for Big Apple?
Is a 700c x 28/38 large enough?
“jagur” <jagur@NoEmail.Message.Poster.at.Unicyclist.com> wrote in message
news:jagur.y707y@NoEmail.Message.Poster.at.Unicyclist.com…
> jagur - Random Unicyclist
> -Forget_Your_Life-
> jagur’s Profile: http://www.unicyclist.com/profile/502
> View this thread: http://www.unicyclist.com/thread/29320
Re: Re: Tube size for Big Apple?
No. Figure on about 25 mm per inch and subtract a bit for the casing. You need something in the 50-60 mm class.
So a 28/38mm is fits a tire from an inch to an inch and a half in diameter. If you use it it will have to stretch a lot to make contact with your big tire. At best is will just lose a lot of air through the thinned out rubber, at worst it will rupture, and no doubt at the worst time. Murphy rules with this sort of thing.
There are at least 3 suitable tubes available – Quality, Salsa, and WTB, all 700x47/52, all with Presta valve. The WTB one has a neat valve cap.
cyberbellum <cyberbellum@NoEmail.Message.Poster.at.Unicyclist.com> writes:
While I would only use an undersized tubes when I can’t get the right
size, they actually work pretty well. I had one on my mountain bike
for years. It finally failed at the base of the valve stem where I
couldn’t patch it, but worked great until then.
Ken
Hi.
At least in Germany you can get a tube from Schwalbe itself. It’s number 19 in their catalog, and a 40/62-622/638.
<http://www.schwalbe.com/index.pl?punkt=15>
Unfortunately, Schwalbe North America does not sell it.
<http://www.schwalbetires.com/tubes.php>
Regards,
Juergen
I ordered the Big Apple with a ‘matching’ tube, leaving it to the
retailer to figure out what that meant. I remember I found the tube
somewhat small, but I didn’t measure it. However I did weigh it: 213.7
grams. It’s been on for about 3 months now without problems. Holds air
fine.
“Friends don’t let friends drop to flat - Kris Holm, discussing large drops to flat ground.”
its ok to use an under sized tube but the problem with doing it is the area around valve stem doesnt over inflate evenly.if you pump up the tube outside the tyre its easy to see this.
this may show up on the outside of the tyre somtimes leaving a weak under inflated spot on the wheel.
Although it’s awkward to put on you can also use a 26" tube.
Leo White
jagur <jagur@NoEmail.Message.Poster.at.Unicyclist.com> writes:
> it ok to use an under sized tube but the problem with doing it is the
No it won’t.
Well, technically yes, but not enough to be noticed.*
That’s because you put much more pressure in the tube than it takes to
inflate it to size. Even when you use an undersized tube withh a low
pressure tire. Sure it looks funny when inflated by itself, but with
tire and rim pressing on it, the tube quickly assumes the proper
shape. The problem is that this does add stress around the valve
area, which will fail after months or years of riding.
Ken
*Unless you find an innertube that’s much stiffer than the normal ones
I buy and use it in a low pressure tire. But then, low pressure tires
have stiff sidewalls to prevent pinch flats, so maybe you still
wouldn’t notice after all.
I’ve got a 29er inner tube in mine, it’s 700x40-50 or something like that.
Make sure you put a decent pressure into it (I use 60ish PSI) or else it’s squidgely and wants to turn corners all the time.
Oh and if your rim isn’t centred right, or isn’t quite true it does funny things too.
It’s quite a fussy tyre, but once you get it right, it’s super magic and totally worth it.
Joe
On Wed, 10 Dec 2003 01:44:44 -0600, juergen_brauckmann
I found the packing my tube came in, and that’s the one.
Is there anywhere that I can buy a Schwalbe Big Apple 28x2.35 tire in the US? Or any other tire of the same diameter? Also what are the widest 700cc rims I can buy?
I ordered my Big Apple directly from Schwalbe
(http://www.schwalbetires.com). I’m using an Alex Adventurer rim.
There was a “700c rims” thread in r.s.u. in February 2003. Among others,
the Rhyno Lite rim was recommended.
“Amos_And_Ego” <Amos_And_Ego@NoEmail.Message.Poster.at.Unicyclist.com> wrote
in message
news:Amos_And_Ego.ybqtb@NoEmail.Message.Poster.at.Unicyclist.com…
> Amos_And_Ego
> Amos_And_Ego’s Profile: http://www.unicyclist.com/profile/4987
